Structure240sx »
https://forums.nicoclub.com/structure240sx-u1949.html
Tue Mar 21, 2006 10:16 am
low throttle i set to 20%. i came to this since that at any rate of normal cruising i never get past that, at most about 17%
my HI setting is set to 40% right about where my turbo starts to spool
for the low map you want to tune right around 14.7. usually what you find your idle to be the same number will work across the board. the stock ecu makes alot of correction for idle and cruise based on open loop o2 sensor operation
