I have done research on this and yes I found the link above with all ebay product review.
The reason I ask is maybe perhaps someones have some success with a particular product.
and to say they are all(turbo) crap is well
there are a few.
and as always if YOU have personal experience with china product and it blew DID you opened up the turbo and cleaned it? its a common issues with china stuff to have metal shavings inside.
I for one use a gt45 and x02 60mm wg and no problem on my v8.
Heres a link to the success story of this gt45.
http://www.theturboforums.com/smf/diy-a ... ?topicseen
500whp+ not bad for a $300 turbo
anyways back to topic what are the other options.
from what ive found
gt2871r
gt28rs
gt3071r
gt2860rs
ive seen one 16g
all of which are over 1k. for a mere 300 I dont really feel like spending that much on a turbo. there has to be a cheaper option.
anyone tried ct26 upgraded from a supra? ive had 57 trim before and made good power(on a 7m though)
my goals are simple:
300-325whp no more no less.
application:
street driven with some 1/4 and highway runs. a little laggy turbo isnt a problem. nothing a launch control/preload cant fix.
NO more than 19psi and PUMP gas
but around 15psi prefered
and lastly would like it to be around $500 give or take.
the thing im considering are masterpower turbo. based on my background t70 has proven success but it might just be way to big on a ca.
any one has a suggestion?
btw how well does stock hg hold 19psi? people say its the best way to go. but i will be doing the hg so i can go metal if needed.
and if it matters these will accompany it:
z32 maf
460cc injectors (rx7) but may decide 550 or 720
walbro pump
arp stud
KA24 Throttle body
ebay exhaust manifold
3" exhaust
fmic
aeromotive fpr
chipped ecu then fine tuned with safc
wideband
I also have methanol injection from my last build that ill be adding for more "safeguard" and cooling.
did i forget anything?
thanks
