Whats a better way to GO?
inorby23
Car: 95 Nissan 240sx SE
i have about $1000 saved, i can work on my own car an have a shop to do all the work in, but im wondering what i should do first for high compression. i already have a high flow cat back and a long ram cold air intake, whats next for my 1000 spent wisely on my 95 s14 240sx?
Hijacker
Car: '92 240sx Convertible
'94 F-150
You would have to tear your motor apart and install high compression pistons. You would find more info on building a KA in the KA forums.
However, you won't see the gain from going with high comp pistons that you would from going with a turbo setup.
Since you've done a catback setup, and have an intake, you should consider doing headers. Past that, you've done all you can for bolt ons and would have to look at headwork and piston/headgasket replacements to get more power out of an N/A motor.
