whats a better swap for my 240sx a rb20 or the sr20
Including VA, WV, MD, DE, DC, NJ, PA, CT, RI, NY, MA, NH, VT, and ME
james_24151
i've bought a 240sx with a blown motor in it and i'm planing on just swaping it out what would yall recomend the sr20 or the rb20 i've compared both power scales there bout the same in that and in finacle there bout the same just not sure which would be the best any suggestions would be great
Nissan Junky
Car: 90 s13
Well for you question i do not own nether one but in the future i will. If you go rb its the same hp as the sr but what you have to consider is the power to weight ratio and they sell more parts for an sr then a rb20 so try doing a little research before you do anything ,also it all in what you want to spend but spend it wise and don't half a** it.
mr.li
Car: zenki
why not throw in a ka single cam or twin cam for less than 500buks, then throw on a turbokit from jgstools.com or somthing, with jimwolf ecu. that make the car fun and reliable. but to answer your question, sr20 has many more parts available. and if you want rb, why not rb25, i'ts bout 600buks more than the rb20.
flohtingPoint
Car: 2004 Z16 Corvette Z06
RB20 day in and day out. It's a far better constructed motor than the SR. Do a board search for comparison, as listing the advantages of an RB20 over an SR would cause me carpal tunnel.
Rb240Coupe
Car: 1990 Nissan 240sx
Honestly it comes down to a personal choice. There both great motors and parts for the rb are hard to come by.
Im still droping an rb25 in mine
psycodrifter
Car: s14 nissan 240 sx 1995/ hydrolocked honda prelude 97 rip
the real question is how deep are your pockets going with the rb is always the better way because it's a better motor to start with but parts are expensive for it but turn up the boost and you are good it can take a beating and them some , sr20det is a great motor also but if you want anything past 320 hp you neep to do some work to it red top is a better platform to build up but i personnally went with the blacktop because it's a newer motor and ball bearing turbo and decent power without going crazy .
moulton712
Car: coupe, hatch, both s13s
both at the same time.
Return to “Northeast Region”
