what you will need after you actually get your sr.
jazz4890
Car: 1991 Nissan 240sx
So I bought an sr and I didn't realize how much stuff you really need after you actually get your motor so I am making a list of things you will need after you get your motor to actually get your motor in your car and to get it running the same day.
1.intercooler + piping2.blow off valve3.most likely but not all of the time a new clutch4.walbro 255 fuel pump is a must5.intake cone with maf adaptor6.oil I recommend royal purple amazing stuff7.trans fluid8.rad fluid9.downpipe10.radiator
Keep in mind this is just a list of things you will need if you just wanna get the motor running it doesn't include the things that may need to be replaced on your motor.
J240sx
Car: 89 240sx
If your short on money you can use the ka radiator, just get different hoses. Dont forget heater hoses.
jazz4890
thanks if anyone else thinks of something to add to the list please dont hesitate to tell me so i can add it to the list.
Acuratechva
Car: Black Kouki
if this is for S14 sr in to S14 then you can make the ka hoses fit perfectly with no kinks.
cody180sx
Car: s14 rb25det fully built 550whp coming soon
couplers for the pipingspark plugsvacuum line fuel filterclutch fluid(if u take off the slave cylinder)assortment of clamps turbo clamps for couplers(turbonectics makes some beast turbo clamps not going to blow those off turbonectics t-bolt clamps i think there called)
o and some 91 or 93 octane gas (cause u know u used 87 before u parked it)
Justin35ll
Car: s13 coupe sr20det
I fell in the same ditch lol. Bought my SR before reallly knowing a lot about it and what else I would need to complete the swap.
Ended up spending almost an extra 2000$ on everything you listed + more.Still need -engine mountsdownpipesparkplugsegr block off plug1 exhuast mani stud/nut/spacercatback exhuastengine, gear oil/ coolant'
Nothing extremely major, but still sucking me dry
All supporting mods I've bought so far-Aluminum radiator/fans/hoses-clutchmasters stage 3 clutch kit-FMIC with greddy flanged hotpipe and BOV-Nissan OEM gasket rebuild kit-Stainless clutch/brakes/turbo lines-Greddy RAS-Wireharness-Flywheel resurfaced-Walbro pump-ARP head studs-New rear trans seal and release bearing-fuel and oil filter-Ebay maf adapter (POS doesn't line up lol)think that's it
Tulsa_S-13
Car: 1991 SR 240sx
After you get an SR you need to get a well paying job so you can afford aftermarket goodies
Slammed95S14
Car: 2001 R50
After I got my swap, they didn't send me everything. They left out the ignitor and the boost pressure sensor. Obviously the car won't run without the ignitor so I had to buy one of those.
But this is a good idea for new sr people.
jazz4890
thank you and yeah I put this up for people who just want to get the car running as quickly as possible so im just putting down things almost everyone will need when they buy just the motor.
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
Tulsa_S-13 wrote:After you get an SR you need to get a well paying job so you can afford aftermarket goodies
+100 and make sure they offer ample time off so you can replace the rest of the stuff you didn't when you first installed it.....I still love it though
cody180sx
and some of the stuff u cheaped out on lol
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
Don't forget about the many bars of soap you will need to wash out your mouth from cursing all the time when you start chasing down the SR startup engine gremlins!!!
