infg35coupe »
https://forums.nicoclub.com/infg35coupe-u128561.html
Mon Mar 16, 2009 1:44 am
American Bankers - Powertrain Plan Download ContractEngine GroupAll internal lubricated parts; engine block; engine head(s); exhaust manifold; expansion plugs; intake manifold; mounts; oil pan; super/turbocharger; timing belt or chain; valve cover(s); water pump; seals and gaskets.
Transmission Group (Including Transfer Case if Four Wheel Drive)All internal lubricated parts within the transmission and transfer case; cooler lines (metal); mounts; throttle valve cable; torque converter; transmission and transfer case housings; vacuum modulator; seals and gaskets.
Front/Rear Wheel Drive GroupAll internal lubricated parts within the drive/trans-axle assembly including: axles and axle shafts; constant velocity joints (but not constant velocity boots or related failures); drive/trans-axle housing; drive shaft support; front hub bearings; front hub locking assemblies (four wheel drive); propeller shafts; universal joints; seals and gaskets.
Fluids and filters are included in conjunction with a covered repair
Additional Benefits - The additional benefits listed below are included with every coverage level.
24 Hour Roadside Assistance - In the event your vehicle is disabled during the term of your coverage, Roadside Assistance Service is provided. These services include: towing, battery jump start, flat tire assistance, fuel, oil, fluid and water delivery and lock out service. Rental Vehicle Assistance - In the event of a covered Mechanical Breakdown during the term of your coverage, you will be reimbursed for rental car expenses according to the schedule in your agreement. If repairs are delayed due to parts unavailability, you may be entitled to additional days of alternate transportation. Tire Protection - If the tires on your vehicle are damaged during their normal life by glass, nails, or other road hazards, they will be repaired, or replaced if not repairable, by a new tire of like kind and quality. Trip Interruption - You can be reimbursed for meals and lodging up to 3 days if you are stranded because of a covered breakdown more than 100 miles away from your home. --------------------------------------------------------------------------------Available Terms: New Vehicles** 36 month / 54,000 mile 36 month / 60,000 mile 48 month / 48,000 mile 48 month / 60,000 mile 48 month / 72,000 mile 48 month / 90,000 mile 48 month / 100,000 mile 60 month / 50,000 mile 60 month / 60,000 mile 60 month / 75,000 mile 60 month / 100,000 mile 60 month / 120,000 mile 72 month / 72,000 mile 72 month / 100,000 mile 72 month / 120,000 mile 84 month / 100,000 mile 120 month / 100,000 mile *Current and 4 prior model years; 50,000 miles or less on the odometer. Used Vehicles* 12 month / 12,000 mile 24 month / 24,000 mile 36 month / 36,000 mile 48 month / 48,000 mile **Current and 7 prior model years; 100,000 miles or less on the odometer American Bankers Insurance - Classic Download ContractClassic CoverageIncludes all Powertrain Coverage in addition to the following components.
Brake GroupBrake booster; calipers; combination valve; lines and fittings (metal only); master cylinder; wheel cylinders; seals and gaskets.
Front Suspension GroupBall joints; control arms: bushings and shafts; kingpins and kingpin bushings; spindles; wheel bearings; wheel seals; seals and gaskets.
Steering GroupAll internal lubricated parts within the steering gear and power steering pump; power cylinder; steering gear and pump housing; seals and gaskets.
Electrical GroupAlternator; alternator voltage regulator; brake light switch; distributor: bushings, gear, housing and shaft (excludes cap, rotor and wires); horns; ignition coil; ignition switch (excludes lock cylinder and coded keys); starter: motor, solenoid and starter relay (excludes any damage to flywheel, flexplate and ring gear); and windshield wiper motor.
Air Conditioning GroupAccumulator; blower motor; compressor: bearings, clutch, internal parts and pulley; condenser; evaporator; receiver/dryer; seals and gaskets; compressor housing; and refrigerant ONLY if needed in conjunction with the repair of an above listed part.
Fuel GroupFuel pump; fuel tank; metal fuel lines; fuel injectors; fuel distributor; fuel injection pump; diesel injectors; diesel injector pump; and vacuum booster pump.
Anti-Lock Brake SystemAccumulator; electronic control unit and module; hydraulic pump; isolation dump valve; relays and sensors (excludes sensor rings).
Cooling SystemCooling fan: blade assembly, clutch and motor; heater core; radiator; thermostat; seals and gaskets.
Comprehensive PackageAir conditioning: orifice tube, suction control devices and thermostatic expansion valve; antenna motor and mast (power factory installed only); door lock actuators/solenoids (power only); ignition cylinder; keyless entry system; ignition module; main electronic control unit; door lock switches; window switches; washer pump motor; power window: gear, motor, and regulator; and 4x4 engagement motor.
24 Hour Roadside Assistance - In the event your vehicle is disabled during the term of your coverage, Roadside Assistance Service is provided. These services include: towing, battery jump start, flat tire assistance, fuel, oil, fluid and water delivery and lock out service. Rental Vehicle Assistance - In the event of a covered Mechanical Breakdown during the term of your coverage, you will be reimbursed for rental car expenses according to the schedule in your agreement. If repairs are delayed due to parts unavailability, you may be entitled to additional days of alternate transportation. Tire Protection - If the tires on your vehicle are damaged during their normal life by glass, nails, or other road hazards, they will be repaired, or replaced if not repairable, by a new tire of like kind and quality. Trip Interruption - You can be reimbursed for meals and lodging up to 3 days if you are stranded because of a covered breakdown more than 100 miles away from your home. --------------------------------------------------------------------------------Available Terms: New Vehicles* 36 month / 54,000 mile 36 month / 60,000 mile 48 month / 48,000 mile 48 month / 60,000 mile 48 month / 72,000 mile 48 month / 90,000 mile 48 month / 100,000 mile 60 month / 50,000 mile 60 month / 60,000 mile 60 month / 75,000 mile 60 month / 100,000 mile 60 month / 120,000 mile 72 month / 72,000 mile 72 month / 100,000 mile 72 month / 120,000 mile 84 month / 100,000 mile 120 month / 100,000 mile *Current and 4 prior model years; 50,000 miles or less on the odometer. Used Vehicles** 12 month / 12,000 mile 24 month / 24,000 mile 36 month / 36,000 mile 48 month / 18,000 mile **Current and 7 prior model years; 100,000 miles or less on the odometer American Bankers Insurance - Ultimate Download ContractThe Ultimate plan most closely resembles the original manufacturer's warranty and provides the most complete coverage available.
As opposed to other plans which list what is and is not covered, the Ultimate plan simply states that your vehicle is covered for, "Any breakdown of your vehicle less the deductible, except for items and exclusions listed."
Excluded items are generally normal maintenance parts and services (such as light bulbs, windshield wiper blades, etc), trim items and other conditions such as abuse. Speak to one of our friendly agents to get a sample copy of the contract which lists all exclusions.
Optional coverage (called the Luxury Package) covers the new high tech items such as factory installed GPS / Navigation System; Night Vision System; and Video Components including TV/VCR/DVD/Video Game Player.
Additional Benefits - additional benefits listed below are included with every coverage level.
