2_Liter_Turbo »
https://forums.nicoclub.com/2-liter-turbo-u12924.html
Thu Mar 09, 2006 3:22 pm
Well, I plan to build an n/a setup on my B13 (my S13 is turbo'd). I was just going to use the standard highport DE because (at least with honda's) the only difference between VVL and a standard setup (when it comes to heads) is that you can have a nice high cam profile at higher Rpm's and a nice "idle" profile, well, at idle. So when building a strong motor, wouldn't it be better to just have no VVL since you wouldn't be worried about Idle, and that is just less crap to worry about breaking under a heavy load? I was going to put in the SR16VE pistons into the SR20DE (heard it raises the compression to around 13:1) and run some JWT cams, and some strong rods/bolts/bearings and call it a day as far as the internals go (also RAS, cam gears, and a good headgasket). My goal is about 230 whp, but with a good tune, I believe that this would be fine. I'm pretty new to FWD SR20's and N/A builds as far as they go, but I have worked for a few years doing honda's, as well as about 3 years doing S13 related car "Stuff". The highport heads do flow better, so I really don't see the advantage of the VE SR's unless you want a nice idle. Please inform me if I am mistaken, because I am still new to this area of Nissans. Lol
