x240xdrifter wrote:ok so I have a 89' 240sx (stock) with a 5,000 dollar budget to spend on it, my goal is a ca18det, which would cost 1400 shipped so I actually have a 3600 dollars to spend on my car. I need everything from rims to suspenison to guages to engine etc. so I ask you what would you do with it?, I need help planning out parts and getting a parts sheet. any suggestions would be awesome, thanks guys!
Well it depends on what you want to do with it and what youre trying to get out of the car. What you are saying here is a little "vague" or generic. $3600 dollars can be easily spent on all kinds of parts. I would start by getting a set of sport tires, wheels, adj. coilovers, LSD, and better brake pads. With these parts you can have lots of fun with your car even with the sohc ka assuming that everything else on the car is working properly.
I would buy the ca on the side and rebuilt it on your spare time. Learn the engine, be the engine. You dont have to set the bar so high because if you do and you miss, you'll feel bad that you did. Start with a plain and simple rebuild. Change seals, gaskets, rubber hoses, water pump, oil pump, and so on. Have the block checked, machined, honed, decked, new rings, and if possible new forged pistons etc. etc. Next make sure the head is straight or milled if using a MLS headgasket, 3 anlge valve job, and replace any other small valvetrain part that is out of spec. Last thing id make sure is ok would be the turbo. Get a new one or have it rebuilt. The list goes on into clutches, flywheels, etc. With the things i mentioned it'll add up quick. Try and decide what you really want or what youre trying to do with the car. Be realistic, use common sense, research, study, and plan ahead. Goodluck!
