Bought me a nice little 87 300zx and proceeded to rip the engine a new... orifice. 300 mi later we have jumped a tooth on the crank and its time to put the junkyard engine in. I have about a dozen to chose from so I figure I will pick the lowest miles engine and go from there. Plan A is to just do a timing belt and slap it in. I always hate plan A. Plan B consists of a low mileage doner out of a 87 - 93 maxima or some other similar VG30E choices. I figure a upper and lower gasket kit, oil pump, water pump, and timing belt kit. Last 3.0 I played with was a Yamaha 3.0 in a SHO and I did the 3 cam sensors at the same time. I have found no reference to cam sensor replacement being necessary but if it is, then it is. I figure new clutch and pressure plate while I am in there, weather it is plan A or B I follow through with. I plan to pull the engine next week from the junk yard, so this week will be ordering parts. Any recommended sourcing? Rock auto seems to beat everyone on everything short of the gasket sets on ebay. Thanks for your time and consideration. Not my first eastern car but it dam sure makes me prefer the load of room under the old Town Car or Nova Custom. Almost felt like it would hang with the nova...till she blew
Either way I go I am debating yanking the heads and doing a head gasket as well as the other gaskets. If I do this I can almost guarantee a rering and bearings... along with heads in the shop to be cleaned and tweaked... both of which I am trying to avoid. Cars just being assembled to be a fun little highway car with good mileage when I can stay out of it.
Thanks for your advice and time.
