Rex »
https://forums.nicoclub.com/rex-u6324.html
Thu Jan 06, 2005 6:29 pm
After addressing any KS/o2's etc (before the $5k, cause that's not internal), I'd look for some sodium filled valves or maybe titanium, then something along the lines of pistons. Either to raise compression or with a better burn design. You can get higher compression and dish the piston at the same time, assuming the head will allow for a taller "shoulder" piston. This would allow for some adjustments to the timing, or lower the risk of detonation with the high compression.
That's probably the $5k answer.
