ThisIsSparTTa »
https://forums.nicoclub.com/thisisspartta-u210180.html
Thu Oct 09, 2014 11:20 am
Single Pop, Downpipes, 2.5" exhaust, catback, lightweight flywheel/clutch. 120k kit assuming it had been a while, replace UD pulley with UR if doing that job. Replace EVERY SINGLE rubber hose and pipe under the hood with silicone. Poly steering rack and sway bar bushings. At least all 4 diff bushings and then subframe bushing collars. transmission/diff fluid. EGR, AIV, PRVR, Carbon Cannister delete. Replace power steering high pressure line and J hose. PTU relocation. Some kind of upgrade over stock brake pads. Adjustable tension rods to replace OEMs that will rot. Aftermarket head unit. Replace tweed interior with anything else. Base tune for setup.
Extra credit: Poly bushings for front LCA, full rear poly bushing work, subframe bushings, coilovers, upper control arms if going with bigger wheels, 17" wheels with 245/17 in front and 275/17 in rear. Replace all 4 LCA ball joints and steering rack ball joints. Replace any broken interior pieces.
That would leave you with a solid handling pretty reliable TT. You could keep going with boost controller, injectors and more. Obviously the sky is the limit. But that would be, and is basically the list I'm working through on my 2nd Z32 now.
