elbles »
https://forums.nicoclub.com/elbles-u3033.html
Sat May 03, 2003 6:05 pm
Well, since no one else has mentioned it, I'd also go for the SR20, but I'd also recommend the following:
ASK if the SR comes with an uncut harness, ECU, power steering lines (you'll need those in your 1990, because the lines switched sides of the car with the 1991+ years, and the SR20 engine), etc . . . you'll need all of those things (well, I guess power steering is optional, and you could rework the KA harness/ECU, IIRC, but it'll save you a whole lot of trouble just getting the SR20 parts). If not included with the engine, and I would assume that it is not, these parts will easily run you more than the $500 you think it will cost to have the engine installed. If you still have the money with all of that taken into account, DO IT, by all means. :-)
But, if the money would be an issue at that point, I'd recommend fixing your car before anything else. I don't know if you are exaggerating in your sig, but if your transmission needs work, and your clutch is almost gone, those would be 2 areas I would spend money on. You could get a transmission out of a junker 240 cheap, and clutches aren't bad to do at all if you have either the transmission or the engine out. But I would never add power to a car if the car itself wasn't running right as is. Just my 2 cents . . . (well, lessthanjakejohn also said this, but I was more descriptive ;-)). Then, and only then, take the rest of the money, and fix your car up.
