05civse »
https://forums.nicoclub.com/05civse-u39056.html
Fri Mar 31, 2006 9:57 pm
I am getting an SR20DET front clip (s13) on Monday for sure. Now my question is should I get a blacktop (stock, a couple to choose from around 60K kilometers) or a redtop (importer will throw in a tuned ECU, clips range from 40K-60K kilometers)? I have done a TON of research on the two engines and seem to get the same information, blacktops have better/different pistons, better oil cooling passageways and squirter patterns, a head design made to flow a little better than the redtop, and little cooling fins. There is also people claming that the only difference is the ECU. So here I am trying to decide what to do, stock blacktop with a little more miles or redtop with less miles and a new tuned ECU installed for the same price.
My other question is what are your feelings on buying a clip with modifications? Do you think that this is a sign that it has been driven hard and stock would be better? What about low miles (43K kilometers) with a strut bar, ground kit, and sheepdog BOV? Do you think modifications don't matter as long as the engine has good compression (what is stock for a dry compression test? 160ish?)? I am just having trouble trying to make a decision and I need as much input as I can get.
Thank you all very much for your time, help and input.
