You don't even need all that, but with that you'll be fine. Over kill in those areas is gravy on the rice.singleturboz32 wrote:i am getting pistons but i was thinking not to get rods because they could already stand up to 650+, i am also getting piston rings, performance bearings and a high flow oil pump
Where do you get your info that can back up that claim? I personally know otherwise and not just by one or two occasions. Explain yourself.DustinZ wrote:Stock pistons normally fail after 450hp.
If you avoid detonation you can make 600 whp with a completly stock bottom end. Detonation will wipe out the rod bearings before the pistons on this motor.singleturboz32 wrote:i am getting pistons but i was thinking not to get rods because they could already stand up to 650+, i am also getting piston rings, performance bearings and a high flow oil pump
