mattd1979 »
https://forums.nicoclub.com/mattd1979-u21551.html
Mon Aug 25, 2008 6:55 am
Speaking of 95, the engine that is in the 90, I swapped from a 95 which had around 62k on it. The engine if revved up a couple of times will clear up for about 30 seconds and then start back again. As far as ohming them, I don't recall if I did.
Shortly after I first posted, My nephew used my car to go up to a store and it cut off on him 3 times like turning the key off so he called me and as he was describing what it was doing, it started to get worse and towards the end he could barely keep it running. When he revved it up it wouldn't go past 6500rpm and the car has a NICO ecu installed on level 3. A couple of days before he drove it until it was right at empty and it started surging and stalling on the way to the house so I figured he ran it out. So I went up the road and filled a 5 gallon can with BP 93 and added a bit of ISOHEET as I always do when I fill the tank and the rest of that day it drove fine until today. He said that it is almost acting like the other Q now.I replaced 2 injectors a week ago and replaced the fuel filter and changed the oil in my Q. All injectors ohmed at 13 except for one that was at 15 ohms. The car idles smooth as glass.
