What would cause my engine to start misfiring?
SketchyRollin564
Car: SR hatchback in the werks
So its a new KA thats been in for like two months but its only like my 8th day driving it cuz it was sitting on jackstands a long time blablabla
anyways, when i first got it in, it was misfiring a lot, so i put some NGKs (not platinum tipped) in and that fixed the problem, the car ran smooth and pulled hard
well the whole story is in this threadhttp://forums.nicoclub.com/zer...-back
but i started feeling a loss of power, andnow its misfiring again, and i dont know too much about engines, but does anyone know what the possible causes are?
im thinking maybe i should have used platinum tipped spark plugs, because thats what it says right in the engine bay
or, theres somthing wrong with my engine causing it to go through spark plugs
theres probably a bunch of other possiblities, but like i said, idk much about how engines work and what a bad injector can have to do with a spark plug and all that stuff
anyone wanna point me in the right direction?
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
check the coil and the distributor cap.
wings_s13
Car: 1981 Datsun 280zx
Ok well check you cap and your plugs. you injectors would have something to do with that. if its not that well if you have a aftermarket intake your injectors could be dumping to much fule and your will need a new coil and some new spark plugs. well check that and get back, your being prety veg peoblem let us know.
