Haha good catch, I mean its not blown.sx moneypit wrote:What do you mean,you say your head gasket is blown?
All changed, had a problem with the old fuel pump, it would sturtter around 3k and i put in a new walbro and it doesnt any more.allenms240 wrote:Full tune up? Dizzy rotor. Spark plugs. Spark plug cables. Fuel filter. If its still like that maybe lack of fuel? I.e. fuel pump craping out
Sounds like a good place to start. A clogged converter can certainly effect power output. Does it have a problem revving out?sx moneypit wrote:Check your catalytic converter.
What's your ignition timing set at?celbii wrote:Yep timing is good, even pulled the valve cover and timing marks are good also. Only thing i havent replaced are maf and and ecu, but would they account for a ~50-60 hp loss?
