No exhaust leaks and the wastegate is closed when it should be. I have a muffler installed on it and i can reach my hand under the car to feel for a leak (open WG).
say im cruising at 50 and come upon a slight hill. The extra load will make it detonate, or if I want to go from say 50-55 on a flat surface, that'll cause the detonation too. Seems that when i get over the detonation (just bear it and throttle anyways), it'll go away, but as soon as I start building any boost (even .25 psi), the engine just doesnt want to make power and feels exactly like super-retarded ignition.
Idle is perfect and everything. This problem happened after I washed my engine bay FYI. I took it to a shop and they said it was insufficient fuel, but if I richen it anymore (its already rich as crap), it'll just start 'breaking up' so I am very confident that its not a fuel related problem.
I DO have an aftermarket ignition but i have removed it to troubleshoot this problem.
I just got back from the store and bought some 'water remover' to add to the gas tank as well as some new plugs which I'll install tomorrow. Ive got about a half tank, so im gonna add some more gas (just in case it was bad gas). Im kinda doubting bad gas though because I would think that if the gas did have water in it, that would cause me NOT to detonate.
I checked thoroughly for boost leaks and even bypassed my FMIC and BOV to see if that would help, which it didnt
