I
mutiny wrote:I'm not sure if you are supposed to do this but I put permatex grey gasket maker stuff on the sides of the plugs before I pressed them in the block. did you do that?
I know some guys swear that they have to go in dry, others swear by "lubricating" them with RTV. I have never done them dry, but have seen them done dry and they work fine. So do mine with RTV. So, I am not sure it matters. Remember though if you use RTV you should make sure they holes are completely clean and dry first, and then let the RTV "cure" for like 15 minutes before dumping any coolant in the engine. Not a problem if you have the motor out to replace them, but on many cars you can replace them without pulling the motor. As long as the holes are clean, dry, and the RTV is cured before exposing it to coolant you should be fine.
All sealants are not the same, eahc has it's own speicalty and some are not resistant to ethelene glycol. Read the package before you buy it to make sure it will do what you need it to do! My favorite for this kind of stuff is the "ultra black".
