My guess is my dad has the same color 2002 with premium, Sports, journey, Chrome and navigation pkg. Which means this car should have rear center console radio & climate control with both rear heater power seats that weights lot more than the basic premium,journey or sports pkg Q45. I don't think it's the shocks because I noticed it too when the car was around 30K and I always thought because he carries golf bags in the trunk all the times. Sports pkg. has adjustable shocks that only adjust the fronts struts and rear is not adjustable. Just regular shocks with separate springs not like the 1st and 2nd gen with struts.wildacexxx wrote:what would cause the rear to get like this?
No, Just G50 springs and I got few more comming in next month.maxnix wrote:Don't you have the Espelir for the F50 for sale?
Yes. http://www.espelir.co.jp/nissa....htmlqship96 wrote:Do you have accurate spring rates specs for the G50 espilirs?
If you have any other questions please refer to my classified thread.
No explanation in the classified. Amazing that someone can represent something in total ignorance! Oh well, Caveat Emptor.maxnix wrote:Infiniti Q45 DOWN RATE
Front 40-45 4.6
Rear 30-35 4.2
No units stated. Is the first drop in mm? Is the second spring rate in kg/cm? Who knows?
Guess it's all explained in the classified.
FYI all JDM spring specs are in kg/mm this is pretty much general. The reason I asked to refer to my classified was this thread is not about g50 springs. I don't want to be rude interfere with someone elses thread with different subject.maxnix wrote:No expalnation in the classified. Amazing that someone can represent something in total ignorance! Oh well, Caveat Emptor.
So, if the latter units are Kg/cm, does teh spring rate work out to be like 100 lbs./in. ? Can someone else check the math? Way too soft.
Then (check my arithmetic) that makes the rate 1080 lbs./ in. which would be great for a cement mixer truck.audiovisiony33 wrote:
