How are you running rich on stock setup now? I think there is something else going on that's causing you to run rich.0range_Kouki24O wrote:i only need to set the amount of fuel being put into my motor because im running rich. other than that my car has stock turbo nd stock injectors. would it be ok to jus tune the SAFC or should i jus go standalone
yea i would def check ur computer cuz it might just be something that is clogged or dirty thats causing it to run rich start from there before u get into spending alot of moneyCSUPUEBLOTIM wrote:Dirty mass air flow, o2 sensor (especially if you had a recent headgasket failure), Vacuum leak...Really anything the computer would compensate for to make it run rich. Is it throwing any codes?
