The Jim Wolf ecu doesnt know how much boost you are running though. A standalone would for sure but the JWT program is general.I would say if all you are looking for is 350 hp, no need for the 72 lb injectors. 50lb'ers will max out somewhere around lets say 15-17 psi on a t3/t04e which is around 350-370 at the wheels. They have a 4 bar fuel pressure program but it makes driveability a lil different. If you are planning on pushing more than that, yeah the 72 lb injector program will be fine and plus it runs on stock fuel pressure.One thing to keep in mind though; Dont assume that as soon as you throw in that Jim Wolf ecu you can boost to 15 psi without any problems. I blew one motor at 15 psi and learned the hard way of not dynoing first. I know I know. But dynoing is always key and variables like: fuel pressure, base timing are critical to have right in order to use even the simpler setup of the Jim Wolf ecu. Just learn from me and do it right and dyno first before you crank up the boost and make sure you check spark plugs for a sign of if you are running rich or lean for even the lowest boost level you can possibly run or how much your wastegate spring is rated at.WDRacing wrote:Like C-Kwik said...ur setup will work fine to support 350hp or close to. JWT programs the gniion retard per lb of boost for you. So you should be cool, if ur worried, use the MSD Knock Meter, it works very well.
WD
klattr1 wrote:One thing to keep in mind though; Dont assume that as soon as you throw in that Jim Wolf ecu you can boost to 15 psi without any problems. I blew one motor at 15 psi and learned the hard way of not dynoing first. I know I know. But dynoing is always key and variables like: fuel pressure, base timing are critical to have right in order to use even the simpler setup of the Jim Wolf ecu. Just learn from me and do it right and dyno first before you crank up the boost and make sure you check spark plugs for a sign of if you are running rich or lean for even the lowest boost level you can possibly run or how much your wastegate spring is rated at.
i didnt hear detonation from my motor before i blew it but his was on a built motor. All it took was one more run at 15 psi and the marbles in a can sound was heard throughout the whole world. If you decide to turn up the boost without using a wideband and everything seems to run right and you dont blow your crap up, consider yourself lucky.C-Kwik wrote:Even aside from putting it on a dyno, work up to a boost level. Drive around and listen to the motor. Particularly for detonation. On hot days, pay particularly close attention if you've not run it at that boost in that kind of heat before. It's fairly rare when you can't hear detonation before an engine blows. Unless you are blasting your stereo with not a care in the world. Until you know the boost level is safe, just be careful. Your motor will thank you for it.
