What will it take to put KA24DE in a 89-90S13??
Loofee95SE
Car: u gota sister??
Hey guys, i just got my self a 90 240sx Hatch back with blown engine for $150. with plan on putting turbo in, In the future but seem to can't fine any Ka24E in decent price or mileage. but i got a few KA24DE on hand. just wonder what will it take to swap in DOHC into SOHC chassis??? wiring??? tranmission??? what else???? help please...thanks C :ylsuper rock on!!
Toahk
Car: 97 ....
Click here for your answer
Silent Drifter
Car: '93 Nissan hatch
'90 Nissan coupe
'96 Ford Ranger
Looking for a bike!
well since I got time..If its auto go ahead an do the 5spd swap, youll need a new ecu an wiring harness an the motor an bam you got urself a ka24de in a 90.
lofapoo
Car: Toyota sedan
Don't you have to change the speedo (or was it tach?) and the power steering lines? I know you have to do this to put a SR into the "zenki" S13 so I'm guessing you have to do the same to drop in a KA-D. Hopefully this stuff will be included in your purchase of the engine :|
Loofee95SE
Well i was going to put in KA-D just bc i couldn't find ny SOHC.But since because it will cost almost as much as dropping in CA or SR..I might as well wait a little bit ( end of march or 2nd week of April to get my self a front clip.. what do u think???
Toahk
Car: 97 ....
I doubt dropping in a KA24DE into a zenki chasis will cost nearly as much as a front clip.
Loofee95SE
That what i though, but the cheapest Dohc i found was $750 w 40k miles in it. and that is just for the engine, no transmission or nothing else, no flywheels nothing, just block, head, intake, exhaust, injectors+ rail. so add the cost of everything else..transmission, stater, alternater, clutch, flywheel...etc etc et...:(
Silent Drifter
'90 Nissan coupe
'96 Ford Ranger
Looking for a bike!
I got mine for 35bucks full engine but 205k miles. Pick a transmission an crap up at junkyard for under 100 bucks your good to go.
Loofee95SE
emm, i may need to find out more about that..
Camel
Car: That would be obvious....
Search on my threads. I started a long thread about this a few months ago. Had alot of good info on this....
danielturbo23
Car: Nissan 240sx 1992
I put ka24de in my 1990, you need the ECU, the harness, the mass air flow, you have to modify or twist the power steering line and change the reserve on the left side, the bolt hole are already there. Buy a jobber p-flow and that it's. The only thing doesn't work is my RPM. Is good to change the TPS and the trottle body.
Sil240
Car: Nissan S13 "The One Cam Wonder"
danielturbo23-Whats a Jobber P-Flow??You have to change the Throttle body and the TPS???Why? Wouldn't you just use the DE TB and TPS??
danielturbo23
You need a new cold air intake (p-flow) and be sure you've got the throttle body and the Trottle position sensor of the ka24de. The gas cable fit but its better to have the one for a ka24de.
