what will fit engine to engine, say from an sr20de to ga16de and sr20det
daveydavido
Car: 1994 Sentra(sold)
what parts can you swap with no problems or little fabrication fit, could one put an intake manifold from an sr20de onto ga16de?i used the search a few times and found only a couple similar responses like how the throttle body from an sr20de can fit on ga16de, than wouldnt a sr20det throttle body fit too? what kinds of issues could that create... i have a ga16de in my sentra, and i know a few people that got sr20det's and have stock exhaust manifolds and injectors and stuff like that lying around that they replaced
little help or at least some links??
nametakennow
Car: '06 MINI Cooper S
The exhaust manis are different.
The injectors should cross over.
I'm pretty sure the intake mani wouldn't fit, and even if it did, I fail to see the point.
What exactly are you thinking about doing? Simply swapping over SR parts isn't going to make more power. People go for bigger throttle bodies because there's more air coming in (as with a turbo), for instance.
daveydavido
well i want to build my own turbo kit. i have a buddy that welds, and a buddy that rebuilds turbosits just easier to find sr20 parts for turbo kits, i dont even know where to look for an exhaust manifold, i suppose i could make one, and itll be cheap for a turbo kit so i dont wanna swap an sr20
