Jimefam »
https://forums.nicoclub.com/jimefam-u67951.html
Wed Jul 27, 2011 2:56 pm
So I'm building a 240sx that will be used strictly for drag and am considering a few changes to hopefully drop some weight and free up a little HP. I searched for people who'd done this but didn't have much success. I'm planning on not running the N1 water pump or alternator and instead run an electric water pump and 16v lithium battery. Was curious to here peoples opinions on this? So what say you? Epic fail, to much of a headache, good idea or what else?
The idea is to drop the weight of the alternator and water pump as well as reduce the parasitic drag required to run them. Also I would avoid any potential issues at high revs. The battery weighs 4.5lbs and the 55 gpm waterpump weighs 6lbs. I'm planning on ditching the thermostat(more weight savings!) and instead trigger the pump with the haltech at whatever temp I want and will allow me to run the pump and fans even with the engine off to help with cooling in between passes. What are the possible pro's/cons and do you think it will make a difference vs stock?
