Wulfgang »
https://forums.nicoclub.com/wulfgang-u10889.html
Mon Jul 12, 2004 4:12 am
NTK was the "standard" because that's all there was a few years ago. The NTK replacement sensors used to cost about as much as standard O2 sensors until the manufacturer realized that they had a monopoly. And that's how the $200 wideband sensor was born.
The new Bosch units (there are at least two models with several variations) use newer technology, heat up faster, and provide the same precision. However, they are used on quite a few cars, and are thus really cheap. Depending on the variation you need, it may be only $30.
The difference in wideband controllers is that most of them were designed in the pre-Bosch wideband era and must use the NTK sensor. The sensors are different, and use different heating routines, so the wideband controller manufacturers would have to develop new software and hardware to control the Bosch sensors.
