philipa_240sx wrote:Staying on the boat/RV theme....
If you like a nice clean, non-greasy, matte finish for your dash, nothing beats 303 Aerospace Protectant. This has been the favorite with the boat/RV crowd for years. Use it on any plastics, inside or outside. Also works well to protect weatherstripping.
I agree 100%. Aerospace Protectant 303 is an excellent product for treating the plastic surfaces on your car. It also has an added benefit of hiding fine scratches in plastic surfaces. I initially looked into the product after being intrigued by the products slogan: "SPF 40 for your Stuff". On researching, I discovered 303 was originally developed for aerospace and aviation applications but is usually found and sold in boat and marine accessory stores. When you think about it... a boat has as much, if not more plastic and vinyl than a car, and on the average, spends more time baking in the sun. UV will damage damage plastic so why not use a product that has the added advantage of being designed to protect against UV.
I use it exclusively on ALL the plastic surfaces of my Rogue. It does a great job hiding / covering scuffs and minor scratches on plastic paneling in the cargo bay and door sills. I also use it on the rubber and vinyl in the engine compartment to keep it looking new. The only caution is... Wipe it on, wait a minute or two, then wipe it dry! DO NOT spray it on and walk away or do a half-a** attempt at wiping if off. I personally recommend spraying it on a soft cloth (I use microfiber) then applying it using the cloth versus spraying it directly on the surface. Doing it this way keeps the over spray off your instrument cluster, carpet, window glass etc. NOTE: If you spray it on a surface and leave it dry without wiping it off (gasp), you can get it off by applying more 303 over the same area or use warm water and a cloth. 303 IS NOT like some of those tire black products where you spray it on and walk away.
FROM THE BOTTLE LABEL:
Interior/Exterior: Vinyl & leather interiors, plastics bumpers, fender flares, trim and lenses, car bras, tonneau covers, vinyl soft tops & plastic windows. Spray on and WIPE COMPLETELY DRY.
The only downside might be the cost. Its not cheap. But then nothing good ever is. It runs about $1.00 per ounce! (a 16 ounce bottle cost me $16 bucks) Then again... I'm still on my first bottle and have detailed my Rogue multiple times. Look for it in boating / marine supply stores or shop online.
