What was the mileage on your KA before your went to Boost?
TwoJayZee240
Car: 93 RB25 powered hatch
I just baught another 240. Its a 93 fastback 5 speed with 171k on her. Has anyone on here introduced boost to a KA with this many miles?
480sx
Car: 1996 Pearl White 240sx
Yes, they have.
You really should do a compression check to make sure your motors healthy enough for it though. If the motor is in good shape and worth the effort, at that mileage you should at least change the timing chain, water pump, and oil seals.
That motor is def getting old, you should also check what kind of oil pressure you have before you add boost.
