I did a set of rims on my old Impreza, and they've held up fine so far. I'm sure at 50K miles they'll have some chips and curb rash but for a $20 paint job, who cares?superuber wrote:I wonder how the paint is going to hold up?Why did you paint them?
It's just the lighting. I used satin black spraypaint, because I wanted them to have a little gloss. Flat just looks dirty to me all the time and high gloss looks cheesy. They'll look normal in the sunlight.lino wrote:They look almost like the hyper silver / black chrome look.
That's the key to the paint holding up right there.DoinkMobb wrote:
I need to do a few more coats of black and then a few coats of clearcoat.
Possibly, Monday night or maybe Tues. I should have time to work on them this weekend and then bring them to the shop on Monday morning. It's been really scary driving on wet roads the past few months. I hate crappy tires.superuber wrote:I like them, post some pics on!
Sumitomo HTR Z III245/40/18$11424.3 lbs25.8" diameterapprox. 8.0" tread width on 8" wide rimsddrumman wrote:Very nice job! They look hyper silver/gun metal gray ish instead of black. I wish you'd have gone with 255/40s. Post some pics after you're done.
First of all, those wheels look absolutely awesome! The satin black was an outstanding choice. Second, where'd you get all that excellent intel about the wheel weights and tire diameters? Thats cool.DoinkMobb wrote:
255/40/18$15130.5 lbs26.1" diameterapprox. 8.5" tread width on 8" wide rims
It's just not worth it to me to pay an extra $150 and gain 6.2 lbs of unsprung rotational weight to get an extra 1/2 inch of tread width.
Thanks. They should look extra awesome on the car. I'll probably have to wait until Wed to get them on though, still have to do a few coats.SynisterQ wrote:
300 tread wear index is a little too close to the billiard ball end of the spectrum.DoinkMobb wrote:
You do know the high the number the more miles the tire maker thinks the tire will last .So the high the number the better the tire and long it lasts . Now When it comes to a performance tire the number will be lower cause its made for grip and performance . Touring type tire would be a better buy cause your gonna get performance and traction it cost more but worth the money . With that said if you want a tire with a low treadwear rating then your just spending money on something your gonna be replacing sooner in the future .Maxnix wrote:300 tread wear index is a little too close to the billiard ball end of the spectrum.OEM tire was 180. Nice to be 220 or less, especially if the car has TCS.
Yes, and on a Q45 for the TCS, ABS and "just to have sufficient grip" you want something with a low (numeric) tread wear rating. That's what he was saying.ca18tt1978 wrote:
Dont take my word for it check this link ....http://www.tire-information-wo....html
Too high of a treadwear count is bad for TCS? Why? I'd like to know so I can avoid getting the improper tires.Rex wrote:
That is something to take into consideration. I guess I'll have to beat on these tires and see how they perform as the miles add up.Rex wrote:Look at the reviews and see how many miles people are getting out of the same "tire" on similar vehicles. Lower cost tires start out with good grip (tom impress) then seem to have tread left forever (with lesser grip), but the buyer just thinks about how long they last and feel they're a good tire.
Tire life is based on a number of things. Tread wear is not the only factor. As Dennis says, tires, even when not worn out, should be replaced approximately every 3 to 4 years (that is correct, isn't it Dennis?). Even so, tread wear itself is dependent on a number of things. Carcass design and material, rubber compound, and tread pattern all enter into it, as does actual inflation pressure and the environment they are operated in, and the use they get (load, speed, etc).DoinkMobb wrote:
That tread rating is somewhat irrelevant. It's not standardized so it's not apples to apples. It can give you a general idea of what to expect, but it's not a hard and fast rule.
The Sumitomo HTR Z III was compared against the Yoko ADVAN Sport, among others. The treadwear rating for the Yoko is 180, for the Sumitomo it's 300. The Sumitomo pulled a 0.95g on the skidpad whereas the Yoko pulled a 0.92g. I know that is not the end-all be-all indication of a tire's performance, but it consistently performed on par or slightly better than the Yoko tire.
I really doubt the Sumitomo will last much, if any, longer than the Yoko tire. Similar performance most likely means similar wear. The treadwear rating isn't really the best way to judge a tire's abilities...
ca18tt1978 - if you're buying a high performance tire, you're buying it because you're willing to sacrifice longevity for maximum grip. Perhaps you've never driven a car with max performance tires? They are most definitely worth the money, trust me.
Rex, while you may be correct regarding cheaper tires, that has not been the case with my Bridgestones. I am a lot more sensitive to tire performance than most, and can tell immdiately how tires perform and when they start to deteriorate. So far at one year and 10K miles, they are as good as when new, with little apparent wear. While I no longer drive as fast on the road (wife doesn't like it and speed enforcement is tougher), I still love to corner as hard as I can, and try to not slow down for curves or corners.Rex wrote:Look at the reviews and see how many miles people are getting out of the same "tire" on similar vehicles. Lower cost tires start out with good grip (tom impress) then seem to have tread left forever (with lesser grip), but the buyer just thinks about how long they last and feel they're a good tire.
On a Q, a good tire won't last much more than 12k. If it does, the longer wear comes at a decreased amount of grip later in the tires life.
It's a trade off, as the owner of a >4,000 lb car, do you want grip or long tread life? You can't have both .
"Better" is a relative term. If you want performance, a softer tire is always better short term, given all else is equal, which it never is. PS2 and F1 have super proprietary formulations tenhance wear, but still keep traction even in the wet.ca18tt1978 wrote:
