what vacuum lines can be deleted?
240sxOwner
Car: 93 240sx
I just had to replace my head and i figured i would go ahead and delete all of those annoying vacuum line attached to the back of the head. My AIV and EGR are already deleted. I have heard that all i need from that mess back there is my intake to regulator vacuum...is this true?
What is the best transmission fluid to use for my 5-speed. I heard redline was good but i wanted to see what you guys recommend...
Need answers fast....its going back in the car tuesday. Thanks guys
onosqv
Car: '92 240sx Vert
240sxOwner wrote:I just had to replace my head and i figured i would go ahead and delete all of those annoying vacuum line attached to the back of the head. My AIV and EGR are already deleted. I have heard that all i need from that mess back there is my intake to regulator vacuum...is this true?
The all mighty fiznat can get you started on vacuum line removal: zerothread?id=109345
If you can afford it, go redline - there is also a transmission flushing procedure if you search.
ETTInnov04
Car: 1989 Nissan 240sx fastback
I'm running Redline MT90 and it i wonderful stuff! Big difference. You'll need 3 but will only use 2.5
