What vacuum line is this
goixiz
Car: Cycling and cars
This was plugged up when i got my 1/2 cutI like to know what does this line go to (vacuum i assume)
See picture (yellow arrow)
Thanks in advance
p.s. could be AC because when my ac comes on its 600rpm otherwise its 850rpm
charlotte240
I removed that about a year and a half ago. It's been a while but if my memory serves me correctly, it's for the EGR.
charlotte240
sorry, I just looked a little closer and noticed the piping. I didn't realize you are running a SR. It may be either that or it could be that solenoid that is supposed to limit your boost in 1st gear. It's in the same place as my EGR solenoid on my KA-RPS13 though.
goixiz
please post thanks
turboex
if your not in cally pull it off
goixiz
Currently the black tube has a bolt (plug)Are you asking me to unplug it ???Would that loose vacuum ??
what does that do ???
turboex
Oh sorry i have no a/c i took all that out along with the emisions crap
RobDET
Car: Cars
Whatever that is... I don't have it
Looks like the BCS whitch came with my swap. It was also plugged with a bolt.
dcmxsa
Car: 1990 nissan 240sx
Yea u dont need that..all u need is the ignitor chip that is located on the same bracket..I just mounted mine a safer spot..away from the turbo manifold.
