candela wrote:You make perfect sense but nothing you said interfers with what I said :p You say Im wrong but you typed teh same babble that I did yesterday...
Maybe u r wrong is a bit blunt
. You are right except for the wastegate open signal.
Quote » Electronic boost controllers are different, and in my un-edited post you will see that I speciafically referred to an MBC (ball/spring) in which case vacumm definetly helps control them. I have used a Blitz SBC, Greddy Profec B, TXS 2 stage, hallman and Joe P... I used the hallman and Joe P from the manifold and had better boost control when compared to compared to running off of the comp outlet. [/quote]
What do you mean by better boost control?
Quote »this will help prevent boost spikes and control teh level better overall.[/quote]
Hmmm. I see. Don't really know how reading from the manifold would prevent spikes and maintain PSI level better. It would just make you boost a bit more.
Quote » There are MANY ways to insure you are using a good line and make it very hard to be cut, kinked...etc[/quote]
Yes there are. I just wanted to play it as safe as possible. My line is like a foot long at most and thus reduces the possibilities of something going wrong.
Quote » Boost travels very very quickly my friend and I just say to run that kind of stuff off the manifold (from a block like andrave suggested) because having your wastegate open at a specified PSI and getting its signal from the comp housing and having a boost gauge tapped from the intake manifold... you will be getting different readings. Your wastegate will be opening at a different time and reading than what your gauge says,[/quote]
No... the wastegate will just open when it does (don't know what you mean by diff time)... at the PSI shown by the boost gauge. Maybe the wastegate is seeing a bit more PSI than the gauge is reading... but does that really matter? IMO no, you're just running whatever boost your gauge says. It doesn't matter what PSI you have at the comp outlet, or hot pipe for that matter (unless you wanna know your pressure drop).
Quote » so unless you tap your gauge into that like as well (which makes NO sense) then you don't even know exactly what boost you are running (or as close to it as possible)..... [/quote]Yes that makes no sense :pface
