What type Transmission Fluid
tomflkey
Car: 1985 300ZX
I just purchased a 1985 300zx with Automatic Transmission. The owners manual says the amount but not the type. Anyone know the type?
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Basic Z31 300ZX Information
Screenshot_2020-05-10 information basic_z31_info [Z31 Wiki].png (22.9 KiB) Viewed 1527 times
tomflkey
Car: 1985 300ZX
Thank you for your help.
Rogue One
2022 Honda Pilot SE
Automatics suck, but there are some people who still insist on buying them. All automatic Z31s used the 4N71B transmission. Change the fluid every so often, and check the level every time you change your engine oil. Also, if you overheat your car for whatever reason and it has an automatic, CHANGE THE TRANSMISSION FLUID IMMEDIATELY!!! If you don't, your transmission will blow up as a result of the fluid getting overheated in the cooler and burning inside the transmission, and this is bad. Of course, you could avoid this by putting in a manual transmission, and have more power and economy to boot! The overdrive switch in the automatics has a temperature sensor that does not allow the transmission to shift into overdrive until it is sufficiently warmed up to avoid possible damage. Level 10 makes an upgrade that will allow your transmission to hold 500+ hp. Click here for more details.
