What type of silicone to use for front timing cover?
StryfeS13
Car: 1993 Nissan 240SX
As the title says, what is the best type of silicone to use for the front timing cover? The upper front timing cover, not the bottom.
I'm using Ultra Grey and it keeps on leaking.
Also, does anyone know how to properly route charcoal canister lines?
Modified by StryfeS13 at 10:12 PM 3/9/2010
Modified by StryfeS13 at 10:13 PM 3/9/2010
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
I used Permatex gray for Imports. No leaks so far.
gumby74
Use Hondabond. You can get it from pretty much any Honda parts counter for somewhere between $6 to $8. When that is not available for whatever reason I will use the Permatex ultra grey.
If your seal still leaks however reconsider your application and technique. The 2 mating surfaces must be clean and true. Run a consistent bead of sealant, and I personally let it "skin" for a few minutes before joining the pieces. Tighten all bolts evenly, and do not overtighten for fear of threading/stripping a hole at an in-opportune moment.
As for the charcoal canister, I simply removed it altogether and capped the fittings at the manifold. Just leave the hard line coming from the fuel tank open as a vent.
Pirate_Freder
Car: 1993 240SX Coupe
I used permatex blue for both front covers, valve cover, thermostat housing, etc.;everything involved in the timing rebuild except the oil pan. works like a charm
dirtyfingers2
Car: 1996 240sx SE.
im with gumby! hondabond is pretty damn good stuff!
