onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Tue Dec 30, 2008 10:06 am
"over the counter" is fine. If your car came w/ an owner's manual, all your questions are answered in there.
In any case, for so cal area, 5w30 is the standard. 10w30 will work (from what I remember, I got the best gas mileage out of 5w30 vs other weights when my car was stock.
I've used everything from 5w30 to 10w40 when I was stock & it didn't matter too much except gas mileage - bought whatever was on sale.
20w50 is for turbo'd cars mostly, don't run it in your car... unless you are turbo.
Synthetic vs dino oil - that one you can search for, it's been discussed a million times. I've used both, they are fine. I like synthetic because it allows me to run longer w/o needing to change the oil.
The auto transmission fluid should be something like dextron iv or something - 99% of atf @ local autoparts stores are dextron iv or v (which is compatible as well).
