what type of fluid does a ka manual transmission take?
maxima278
Car: 96 240SX SR20, 69 Ford Pickup, 99 Dodge Ram 1500, 1996 Nissan Maxima, 1997 Nissan Maxima project, 89 Coupe shell
I need to change the fluid, it smells like 80 w90 gear oil but I'm told it is ATF . I need to know today, so any info would be great.thanks
180fan
Car: 89 fastback
It takes GL-4 gear oil.
nissilvat
Car: 1990 240sx
when would the grear oil need to be replaced?, i havent changed mine since i got it a year ago. is that bad?
maxima278
I am doing an engine swap and in the process I drained most of it so I figured why not put all new fluid in. Most of it came out when I removed the shifter
slipnfall
Car: '06 D40
You might come across this at some point of your readings, but I'll tell you now anyways. DON'T buy GL-5 fluid for your transmission. It's been said(many times) that the extended pressure(EP) additives that are abundant in GL-5 will wear our brass syncro's twice as fast.
Just wanted to warn you, because I was told that GL-5 is fine for a GL-4 application. This was from a salesman at an AdvanceAuto parts store, who sounded like he knew what he was talking about. If you can't find a decent brand GL-4 at the auto parts store, go to the dealer. Don't cheap out on it either: you don't have to change it often so you may as well put something good in it. I used MT-90 from http://www.myoilshop.com, and love it.
-Slip
MyCarGoesRawr
I use Redline Heavyduty Shockproof for my transmission and VLSD. Seems to work really well for me.
sanioll
Car: Nissan 240SX SE
Toyota Camry
okay simply use 2.4 quarts of Redline MT-90, GL-4. currently have it for months and loving it.
you can get it from advance auto parts. $7 bucks a bottle, you need to use 2.5, which is 2.4 quarts.
Fenvy
Car: 2005 350Z Base 6MT
read my sig
slipnfall
Car: '06 D40
YOU CAN GET IT AT ADVANCED AUTO??!! Sorry to shout, but I just paid shipping for that stuff!
Argh...
-Slip
maxima278
I looked everywhere for gl-4. I found lots of GL-5 and everybody said it was just better. I finally found some at advance though.
FliMSiCaL
Car: 1989 240sx 1994 sentra limited edition
the stock specs call for 80w90 gear oil......
ArticDragon192
Car: 91 Z32 2+2
Here's a good thread on transmission oils.http://www.club240.com/forums/...n+oil
sanioll
Toyota Camry
this is why you have to do a simple search, NOOB!!
My DIY comes first on the search list here, when you search for "transmission oil" keyword.
see other DIY too, but look into mine if you would like:
here:
zerothread?id=95826
BTW, YOU BETTER RETURN GL-5 BACK. REASON WE DONT USE GL-5 IS BECUASE IT EATS AWAY YOUR TRANNYS SYNCROS. ESPECIALLY YELLOW METAL, BRONZE OR SOME OTHER STUFF.
RETURN IT BACK. GO TO ADVANCE AUTO PARTS, AND ORDER THRU THEM. THEY'LL DELIVER TO THE STORE FOR FREE. THEN U CAN GO AND PICK IT UP.
Dattebayo
The factory service manual says API GL-4*2 is what is recommended.You need 5 1/8 pints, or 2.563 quarts.
You should go with what the FSM recommends every time.
PalmerWMD
Car: 2004 350Z
do not use GL5 ONLY GL4
Fred..
maxima278
they had gl-4 at advance, so I got some. thanks for the info yall
