Ok so I guess If I would want to use this setup I'd have to buy 6? RBTALLY What all did you buy to get this setup on and running correctly?
Those coils are used in conjunction with a Tec3 standalone. I know that car personally. It was built by a Trinidadian guy down in Ft Lauderdale. Makes 900hp on race gas and sounds friggin' mean. He just sold it recently, however. The car was built by Drag International and they have had excellent results with the Tec3 on RB motors. Nate's setup would probably be cheaper though...Chaos the Xile wrote:Look at the pic and tell me if you know what brand theses are and where I may be able to purchase them?
haltech or other computer MSD DIS4 box ... you only need 3 coil packs..The guys at Drag International are very nice I have spent a lot $'s with them this year on another car.Chaos the Xile wrote:
Who mentioned an RB20?Okinawa_BNR34 wrote:900hp on an RB20DET...hmmm.
he must have had a custom made counter balance crank, forged internals, and some serious headwork. even then, the block would be questionable...
some questions on this build:
1) what turbo, injectors, oil pump, and water pump.k was he running?
2) who makes aftermarket stuff for RB20's in the US?
3) does he have a dyno printout?
Yes it plugs into the gray partmeet07 wrote:So where does the wiring go on these GM DIS style coils??
Are they on the bottom where the light grey is??
Well the coils plug into a gm ingitor, so I haven't found a plug for it so I just made my own(if anyone has any information on the 6cyl ignitor that would be helpful)meet07 wrote:But what kind of plugs are you guys using??
No, you'll burn up ur ecumeet07 wrote:is there a way to run any of the dis GM coils and bypassing the ingniter
