what type of clutch to get??
sr20-thoj
Car: 89 nissan 240sx coupe
I really need a new clutch cause I think it just went out... What type of clutch should I get for my s13 blacktop... I need some feed back on which one to buy.. I wanna keep it below $400 also.. should I also get a flywheel while im looking for a clutch also??
S13240
If drag racing I'd stick with the stock flywheel with an ACT street strip if you're looking at about 350whp or Exedy stage 2(3 puck). Gotta think about hp and what you're gonna be doing with it then upgrade from there.
myst303
Car: 89 S13
I put in an ACT street/strip clutch w/ HD pressure plate, and a prolight 10lb flywheel. Haven't had any complaints and it's a daily driver.
sr20-thoj
Theres three clutch kits i have in mind.. ACT, SPEC and EXEDY.. Not sure which one to get at all.. Im aiming more on drift/drag.. Im looking to get anywhere from 300-350hp.. anyone with experience on these clutches, please leave feedbacks.. also what stage should it be??
otterman
S13240 wrote:Exedy stage 2(3 puck).
Thats the clutch I got and I love it. It's really heavy though, it takes a little bit to get used to it. I'd go with that, its rated to 400hp.
da40
Car: 1995 SE 240sx
exedy stage 2 thats a sweeeeet puck
sr20-thoj
thanks guys.. exedy it is.. ill let you guys know how it is when im done.. should I also get a flywheel?? or is stock flywheel fine??
Wolfe
Car: 1991 Nissan 240sx
I have a fidanza 12 lb on my sr20det and I like it alot better than the stock. the rpms are much more "useable" and for drifting its worth the $250 I spent on it on ebay.
twofourzeroSX
Car: 91 sileighty
i like my exedy flywheel, revs real nice. and im using the act ss but im replacing the disk with the 6 puck disk for a little more grip
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
under $400? That definitly leaves out the flywheel upgrade. I went with the ACT Street/Strip clutch (stock flywheel) back when i had my swap done. Its been holding great for over 25 passes of drag racing and alot of street racing. Im also pushing near 400whp with it and no slipping occurs. Definilty a good clutch for the money.
95lstegman
Car: 1989 570SX, 2005 Acura RSX, 1994 Toyota Corolla
i may not be making huge power, but i'm using the Spec Stage 2. i LOVE the way it drives. hardly any chatter. if you slip at 1000rpm you won't have any at all. it only shows up down below about 800rpm slipping. holds great, shifts great, and very easy to drive, although of course it has a heavy pedal. it's also rated for 380ft*lbs, which equates to about 305-310ft*lbs at the wheels, which is a hair over what most 300whp SR's make, so if you're thinking about 300whp and don't plan on drag racing, it's probably going to be fine for you. and it doesn't have any of the annoying qualities of a puck clutch, like engagement that can be too quick or bad chatter. don't get me wrong, if i dump the clutch, she grabs HARD, but i'm only making 214ft*lbs of the available 305-310, so i'm nowhere near maxing it out. it's not full-faced, but windowed kevlar, FYI.
that said, SPEC was a BEEOTCH with me. i got a great price from Enjuku, but now that i've installed it i find that the clutch disc springs are not balanced properly and my rear end vibrates under decel, esp. in 4th gear and only between 3000-2000rpm. they won't help me at all other than to sell me a new disc. they offered to take my disc and look at it but he was sure it was fine. "we've sold hundreds of Nissan discs all with the same springs . . . i mean, each application has springs for that application, and nobody has reported a problem". yeah, when he made the correction he sounded like an idiot. i won't be buying another SPEC just b/c of that guy. but the clutch WORKS extremely well.
