What turbo to go with my new Built motor???
Solow240sx
Car: sr20 powered 91 240sx
Ok guys heres where i am at in my build, I am trying to figure out what turbo to run on my new motor, i will post a list of mods done to the motor below, Im looking for around 450rwhp, I was going to stick with my bottom mount set-up but decided it would not get me where i wanted to be and since i have fully built this thing i my's well do it all this time and be happy with it, so i have decided to go top mount and have been looking at the peakboost topmount kit with the t3/to4e, Can anyone tell me if this turbo will get me where i want to be hp wise, what rpm it will be hitting fullboost, and will be be laggy??, Or would it be better to go with the gt30 series turbos?? Theres a choice of 400hp & 500hp kits on phase2 could anyone tell me the difference, anyways thanks for any help in advance, heres the build details!!
Sr20det redtopCP Forged 86.5mm-8.5x1 .20 over pistons eagle forged H beam rods with arp bolts Acl race rod and main bearingsARP main studsWet Magged & polished crankBalanced rotating assemblyApexi 1.5mm headgasketARP HeadstudsGreddy rocker arm stoppersBrian Crower stage 2, 264 camsBrian Crower Valve springs and titanuim retainersMegan 3" downpipe Apexi N1 3" Catback Greddy front mount intercoolerGreddy FMIC pipingGreddy type rs blow off valveApexi power intake kit
Coming soon:Greddy intake manifold, Aluminuim flywheel, and either 740 or 810cc injectors...
nzmoman
Car: 240sx 2 of em' and always lookin for more
you've already picked injectors but not the turbo....
what are you doing with the motor? drift, drag, daily, autox? that will matter when choosing a turbo...
Solow240sx
No i have not ordered them yet, i'd just like to stay with 740's or 810's.
It will mostly be drag raced, with the occansional drift session, it will be driven on the streets also every once in awhile..
jr_ss
Car: 95' S14
You're going to want something that'll spool in the 4k range and pull all the way to redline, whatever that may be... The T/S 3071r is a great turbo for this... If you're looking for DD and faster spool I would run a 2871r. I'm personally going to run an FP 20g on mine... Suppose to have similar spool up as a 2871r, but capable of laying down more power and having a broader power band... I'll be running almost 9.2:1 comp ratio though, so I'll decrease spool time a bit compared to the 8.5:1 guys... Also I'm more into drag and I'll probably still DD her as well... But this setup should be good for auto-x as well.
Solow240sx
That sounds like a great set-up man, i was thinking about going TS with the 3071, but the t3/t40e comes in the peakboost kit and if much cheaper, does anyone no anything about these turbos??
Solow240sx
Also i would like something bigger then the 2871r... I'd like to make between 450-500rwhp...
Kalypso
gt30 is nice,
borgwarner k27's are also husky, and twin scroll.
Solow240sx
Hmmm never heard of the borgwarners, i'm kinda lost on what turbo i want to run with decent spool time, and big power...
jr_ss
Car: 95' S14
You're going to have to sacrafice alittle bit of one for the other. Choose a turbo close to what you want. 3071r is most likely what you are going to want to run. I think Toby is putting down almost 400rwhp, I'm not sure if that's on pump gas or not but that's a powerful car. I think you have some gas stations that offer upper 90's octane fuel if I'm not mistaken. Use that to your advantage. But if you want big power, you're going to have to give alittle up n the spool time..
Solow240sx
Yes i no that, and i am willing to give up some, just need to no what everyone thinks would be a good set-up, Is there anyone that knows about the t3/to4e turbo that comes in the peakboost kit, u can choose from 400, or 500 hp kits, Just wandering how they would preform..
Kalypso
borgwarner!do you know how to read a compressor map?
the phase2 kits differ, in the A/r on the turbine housing... If im not mistaken.
Solow240sx
No i do not no how to read one...
inkslingers13
Car: 1985 Corolla Gt-S
Solow240sx wrote:No i do not no how to read one...
lol its cake man... go with a Borg you cant go wrong...
