C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Thu May 13, 2004 9:56 am
It will work, but not the best match I've seen. At about 1 bar(14.7 psi), you will only have dipped into about the halfway point of the peak efficiency island of that compressor. Yoiu'll start somewhere around the low 70% range at a peak boost of 15 psi. A T04E-50 will have you starting out at the mid 70% efficiency range by the time you hit peak boost and cross through the entire 78% efficiency island and dipping slightly back into the 76% island by redline. With a turbo hitting that kind of efficincy, the more you are able to use it, the more power you will make overall. Peak power may not change much here, but the power band would be slightly broader. So far I do not see any GT series turbos that are providing a better match for a KA than the T04E-50. At least on the compressor side. And in a size that would allow for a reasonably flexible boost curve.
