monkeyofdrift wrote:is it possible to still use the stock turbo manifold, with a custom upmount turbo adapter? I mean use it along with a... lets say gt30~ gt35r turbo??? or would I have to get a whole turbo manifold and then upmount adapter?,Thanks for reading.
if u had to get a manifold, wouldnt u just get a top mount? o_O
the stock manifold is a t3 flange, so u should be able to fit it on. maybe use a spacer. problem with adapters is lag. u could build one using the stock manifold, but lag becomes an issue. u cant just go straight up with the adapter cause youll hit the brake booster, so you gotta custom make a turned one to get it up there.
i did one and it was lag city. looked awesome though
