what turbo is this??? pictures.
tvmendoza
Car: 240sx 95
Hello, this is what happened i bought a turbo for my friend and he gave me his straight T4 but right now i am not sure it is a t4, on the manifold it fits the t3 so it might be a t3 or a t3/t4 what do you guys think?? ok i dont have idea on how to include the pictures hahahahah someone help me with that first.(i saw the mountain icon put it just puts [IMG][/IMG] )
fiznat
Car: Grown up :(
You need to upload the images first. You can do that for free on NICO here:
http://nissaninfiniticlub.net/photopost/
After that, you paste the URL of the image in between those [IMG] tags.
tvmendoza
Car: 240sx 95
Thanks man. Here it comes. That is my car: Turbo: Is that hole normal???
i hope it works
sunnys14
Car: S14
too blurry to tell... resize your pictures also
Structure240sx
definitly looking like a t3 with a t4 compressor, normal hybrid turbo
that hole on the compressor housing is if you want to run a vaccum/boost source for your wastegate. you just need a fitting for it or you can put a bolt in there to block it off and run a vaccum/boost source from the intake maniold
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
Structure240sx wrote:definitly looking like a t3 with a t4 compressor, normal hybrid turbo...
Agreed.
See the ".63" stamped in the turbine housing? That's a turbine A/R, and T4 turbine's don't come in .63...
Should be a good turbo for the KA, assuming the compressor is a 50, 57, or 60 trim (to find out which, measure the minor and major diameters of the compressor wheel).
- Brian
DRIFTEADOR
right, except you dont want to use that port as a vacuum source. boost only.
Structure240sx
sorry i should have specified about that port, only for the wastegate source if you choose to use it
tvmendoza
Car: 240sx 95
so i can use that port for the external wastegate or is it just for internal?Also how many psi should i run on this turbo.My setup so far is:sr injectors, safc II, fmic,xs power bov,SSAC mani, stock internals, my friend will make the IC pipes and the downpipe. Please do not tell me that that you will not run with SSAC since when i bought it i was not on the forum and i want to use it until it brakes if it last one month it will be ok. My first upgrade once the car is running will be the manifold. Thanks in advance
virus77
Car: 95 S14, 71 240z, 97 e320
You can go internal or external, im selling a internal wastegate for that turbo for 50 bucks, its set at 7 psi and has an adjustable actuator aswell. Its from my old turbo, almost the same thing as the one in your pics. With your setup I would say 8 psi is a nice safe number.
tvmendoza
Car: 240sx 95
That is a nice price, but the mani has the hole for the external WG, let me see if i can block it, if i do not have the money to buy the external i will send you an email. Thanks for the fast reply.
tvmendoza
Car: 240sx 95
Hello, today i talk with my friend and i told him what you said about the turbo and he said that the turbo has T4 internals. Is that possible? if it is possible 8 psi will be a lot??Also where is the best place to run the bov
Structure240sx
some precision turbos use a t4 turbine wheel in a t3 housing that is bored out, not too sure about your turbo
tvmendoza
Car: 240sx 95
lets say it is a t4/t4 is 8 psi too much???Also (a little bit out of topic) what should be the A/F ratio of a stock ka24de (1995)???
