themadscientist wrote:I was curious what screw pressurizes your CA18. Please identify as much as you can about your power booster.
Make?
Model?
Where did you get it?
How much?
A/R ratio?
Boost level?
Best power achieved so far?
How it behaves, it's response, where it falls off etc.
Supporting mods made to the engine that impact the the previous. Cams, modifications to or replacement of intake or exhuast manifolds, intercooler size and maker, pipe diameters, throttle body changes etc.
Do you like it, would you buy it again or do you find yourself looking at something different?
If we can fill up a thread with good thorough reviews it could serve as a help to those that follow when they need to get a turbo. It can be overwhelming with all the choices out there and the specious opinions masquerading as fact. Real world testimonials can be invaluable.
Hmmm, 3 cars, 3 different turbos, 3 different camshaft set-ups, all uses the same standalone system, 2 use the same boost controller, let's begin.
Car #1= 1993 240sx coupe with a silvia front, internally stock CA18det with custom reground camshafts, a turbonetics 60-1 with a .70 front housing and .63 exhaust housing, 750cc injectors, 3in intercooler piping and an MSD DIS-2 ignition system. I traded a CA18DET for the turbo, but it was brand new when I got it. It is mated to a heavily modified SSAC top mount manifold and dumps exhaust through an HKS 40mm wastgate. This car has never seen a dyno, so it is tuned from experience and it runs like pretty good. Actually, this is one of the most quiet CAs I've ever put together.
Car #2= 1988 Nissan sentra with mildly modified CA18det. This particular engine is fortified with HKS (264int. 272ex.) both with 8.5mm lift camshafts, H/D 300zx valve springs, CP pistons, stock rds, balanced and align-bored bottom end, ARP, studs, cometic gasket, ported head, custom exhaust manifold, GT35R ball bearing unit (chinese version), custom intercooler, 2.5in piping, 1000cc injectors, same ecu and ignition system as car #1, and this car too has never been to the dyno in this trim. Actually, this car is not yet finished since it is replacement car of the last sentra that was wrecked.
Car #3= 1989 Nissan sentra with a heavily modified CA18det. This one consists of wiseco slugs, pauter rods, arp bolts throughout the motor, lightened and knife-edged crank, 8lb flywheel, lower assembly balanced, custom intake plenum, 73mm Throttlebody, 1600cc injectors, head is done with JUN 272 10.5mm lift cams x2, JUN valve springs, JUN solid lifters, head is meticulously ported and heavily modified, NISMOOO 1.2 metal headgasket, Tomei cam gears, cutsom exhaust plenum, and the turbo is a T04Z. This is a drag car that's been on hold for years. Will get completed some time this year, but don't ask as I'm a very busy dude with very little time to play with all the toys that I have.
Car #4= Not a nissan, but fun nonetheless. It's a 1995 Hyundai Elantra with a mitsubishi 4G63 engine, a modified 14b turbocharger turned into a 16G and it sits at a whopping 13psi of boost. Just had to add that. Anyways, if you guys want some comparison, check out our dyno charts and read some of mine to see what works with what. And these are all factual and not stated.
Dee
