what turbo is bigger and better?
93RPS13
Car: Cars, Girls, Cars, Food
what is bigger and better between a RB25DET vs. a VG30DETT turbo(300zx) but comparing one vs one? Thanks
93semax
You want a vg30et turbo, not a vg30dett. The vg30dett turbos are tiny. The vg30et turbo is a t3 with a steel turbine. Should be able to boost higher than the rb25 ceramic turbine.
93RPS13
oh ok thanks for the info, do you have to modify the down pipe?
93semax
My downpipe flange looked like it would fit the z31 turbo fine but I don't know for sure :/
93RPS13
ok thanks 93 anyone else?
undertaker
Car: C33
the VG30DET turbo is slightly bigger than the RB and there is a steel turbine version, probably hard to find though.
93RPS13
damn, is there more turbo lag or anything because of the steel blades?
undertaker
Car: C33
i guess so but the durability makes up for it if you intend to run high boost often
93RPS13
ok kool anyone else?
WDRacing
$550 for a brand new T3/T4 in any trim, why go with a used T3??http://store.yahoo.com/cheapturbo/gartur.html
WD
93RPS13
thanks
