damn dude! 1600 bucks for a turbo is too much for me.97s14guy wrote:Check into Turbonetics T3/T4 HiFi .60
I'm looking at that exact turbo but with the turbonetics satge III. The guy tells me that the housings are the same dimentions. I just want to be sure this will mate up to my downpipe the same. What exactely are you saying is different? I'm not quite understanding.C-Kwik wrote:Aside from the GT turbos, A T04E 50 Trim compressor is one of the best matched turbos for the KA over a very wide range of boost. As for the turbine, it really depends on your preferences. A T3 turbine would probably be the easiest choice for you as fitment would be easier. You'll have to decide your trim and A/R based on the response vs power you want.
Keep in mind though, there is a difference between a Turbonetics and Garrett turbine housing. To be more specific, the offset of the inlet to the cetermine of the turbo. Check the dimensions of your turbine against dimensional drawing of the Garrett and Turbonetics housings to determine which you have. This will make it less likely that some sort of modification will be needed.
Notice the dimension I put in the red box. This dimension is different for the Turbonetics design vs the Garrett design. I can't find the Garrett dimension at the moment, but this has been discussed in the KA circle before as some have had success mounting T3's on Revhard manis and some have not. Along with some differences in the master cylinders, this is also known to be a factor in fitment. In any case, just make sure this dimension is the same on any other turbo you decide to get if you want to make sure the rest of your plumbing will fit.Edub1 wrote:
Obviously the turbine housing size and typically the wheel on the compressor side, but alot of 60-1's come in S housings...or is that only 62-1's?hek1620 wrote:what's the difference between the t4/t04e and the t3 60-1?
The A/R is an internal dimension. It has no effect on the outer dimension. What I speak of is a different casting between Garrett and Turbonetics turbine housing designs. The Garrett design places the flange further away from the center axis.hek1620 wrote:how much bigger from flange to opossite end of the turbine housing is a .63 than a .48? i have about the thickness of my pinky before i hit the bmc.
As long as it's made from the same casting or an exact replica. As I said before, the A/R has nothing to do with the casting. Garrett and Turbonetics both make .63 A/R T3 turbine housings, but have different A/Rs. The A/R simply refers to teh size of the nozzle inside the housing. Turbine housing s are built by each manufacturer from the same cast. They just machine the insides differently for the diffrerent trim wheels and A/R.hek1620 wrote:mine is a garrett. so if i move up to a garrett .63 it should be about the same size? do the t3/t04e's come in 5 bolt?
