ITR_KILLR wrote:ok, a 50trim is perfectly matched to the stage III wheel, and 60 trim matches up good with the stage V wheel.
the A/R of the turbine side is important b/c it determines spool-up characteristics. the .63 A/R spools up faster than the .82
good street turbo for 300+ whp50 trim stage III T3/t04E .63 A/R exh sidespools up pretty quick
400+whp50 trim stage III T3/T04E .82 A/R exh sidepretty laggy, buts makes more power
So, if I were looking for a turbo between these two would this be good turbo since it has a larger compressor trim. This would create a little more lag correct?
57 trim T3/TO4E .63 A/R exh side
or click here
I was basing this off of what I read from a person on another forum and ITR_KILLR
Generally, with the compressor wheel (cold side of turbo) lower trim numbers = wider range of efficiency, but lower overall flow capacity. Most compressors wheels are in the 40-65 trim range.
With the exhaust wheel (called turbine wheel often) lower trim numbers mean more energy is recovered from the exhaust gas, meaning a quicker spool, but flow capacity is lower than higher trim wheels. The exhaust turbine wheels are normally in the 60-90 trim range.
A/R ratio refers to the size of the housing. A = area of the entry into the housing. R = radius from the center of the turbine to A. Is he correct?Oh, and thanks in advance
