StevieRay, how did your battery terminals look when you checked out your Q?
I cleaned off and re-seated my battery terminals today since there was quite a bit of corrosion build-up on the negative terminal. I'm hoping that was the cause of the light, so I'll be keeping my eye on the light to see if it comes back.
Q451990 wrote:Check your brake fluid and make sure both chambers are filled to the full line. The fluid tank is partitioned so the front or rear will still work if one set looses fluid. The alternator will typically make the ABS light flicker with it too.
Heath
I should go out and get some brake fluid to top it off or, if I find the time, change out my brake fluid. It kind of looks like it could use a change. Wouldn't you notice a difference in pedal feel if you were low on fluid in one of the chambers though?
goody90q45 wrote:Have you replaced the alternator?
I've never replaced the alternator and I have not seen any indication of it being replaced since 2005 which is as far back as the receipts from the PO go. Lino told me that my alternator looks OEM, possibly original because of the green painted stator. If it's original it's 17 years old with 280,000KM on it (about 174,000 mi).
maxnix wrote:Brake Fluid level or Alternator/Battery or pad sensors.
I think you're mistaken on the last item on that list. The pad sensors are connected to the multi-function display. It's just the parking brake, low fluid level and alternator connected to the light, according to page EL-43 of the 1994 FSM.
