What triggers code P1320? (97 Nissan PU XE)
rentiu
Car: Nissan XE 4x4
I have a 97 Nissan PU 4x4 XE (2.4 L).For some reason the code P1320 keeps on showing up. I reset the computer couple of times (just to be sure), and the light stays off as long as the engine is on. The moment I re-start the engine the light comes back on.(It's only triggered at startup)
I did a minor tune-up including changing the distributor cap and rotor, without any luck.
Anyone knows what else this code could be triggered by?
ThanksL
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
The ignition signal from the primary circuit in the dist. is not being detected by the ecm. Check for a wire that might have rubbed through or backed out of the harness connector at the distributor or coil.
