What transmission fluid can I use ?
Dinkydow
Car: cars
I have an 06 M35X and plan on changing the transaxle, both the front and rear differentials to synthetic. The manual states Nissan D transmission fluid. I do not live near a Infiniti or Nissan dealer and would like to pick up the appropriate fluid at Napa. Is the right fluid type Dexron?? Thank You!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Are you speaking of transmission fluid or differential lubricant?
Dinkydow
Car: cars
Transmission fluid
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
OK, transaxle confused me.
You need the specific Nissanmatic fluid, but I understand Castrol (?) makes a substitute. I would check with Infiniti to be sure it is acceptable. Otherwise you may void your warranty at best.
Dinkydow
Car: cars
Thank you Brian!!
szh
Car: 2018 Tesla Model 3.
The M35 has both a "transmission" fluid that can be replaced (which must be Nissanmatic Fluid J and must be used to avoid voiding the warranty) and a "transfer" fluid (which is Nissanmatic Fluid D or equivalent).
Confusing ... but the Service Manual is clear!
Z
