NJGuy »
https://forums.nicoclub.com/njguy-u191160.html
Tue Jan 10, 2017 6:33 am
The sensor replacement and programming does not have to be done at the dealership.
I think the absolute cheapest way to get it fixed would be to purchase an aftermarket sensor and get it installed. The '08 has the TPMS check switch connector below the dash near the steering wheel, so you could techncially put the system in troubleshooting mode to find out which sensor is bad. Once the new sensor is in, you set the tire pressures in each wheel as specified in the FSM, put the system into the reset mode, and go for a 20 min. drive on the highway to pair the new sensor to the car. I don't know if I'd have the time and patience to do all that, so I'd probably stop by a local tire shop instead and let them take care of the entire job.
As for aftermarket sensors, the VDO SE10001HP REDI-Sensor (314.9 MHz/315 MHz) looks like an option that's both cheap and popular.
